New Gear from Wet Sounds
    Hopefully, everyone is aware if the original BTVC blue tooth receiver and the recently released BTSW blue tooth rocker switch receiver.
    Just today, Wet Sounds starter shipping the new WWBTUR universal hideaway device.
    Receives the signal from any BT enabled device and sends to any amplifier with low level inputs or a head unit with an AUX input.
    • Mounts anywhere. Control-less - Uses the controls on the BT device for Play/Pause, Track & Volume adjustment.
    • Power-saving feature - BT UR turns off the amplifier if music is paused for more than 10-20 seconds. Powers amp on when play is resumed.
    • Indicator lights inside the translucent case: Blue light indicates BT pairing status. Red light indicates amplifier status.
    • Red Wire: +12V, Black Wire: -12V, Blue Wire: Amplifier remote turn on.
    • 3.5mm female connection for main output.
    Retail is $49.99
    Awesome device for off-road enthusiasts
    Germaine Marine
      Yes, absolutely perfect for small systems that do not have a traditional source unit.
