Xmd3 head unit is acting up and both wired remotes are refusing to do anything.. System after a few minutes of playing says hello and refuses to let ya adjust volume unless you hit the mode button for aux again. I would like a bluetooth unit.. Will a m606 or m505 fit?
22v xmd3 time to upgrade
The xmd and m series all require the typical 2" x 7" cutout. However, with OEM installed units with the larger faces like the xmd, cdm, m606, we find that the human cut holes done at the factory tend to be on the liberal side. This is possible because the large face will cover the not so exact hole. This can be an issue when you move to a unit like the M505 that has a more traditional rectangle face. The retaining cradle does may not fit well and it will certainly not cover the mounting screw holes left by the other units.
So yes, the M505 and M606 will fit, however, there may need to be some fabrication done in order to complete the job so it both looks good and the unit it secured.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
