Folks, I recently (Friday) added a third battery on our 2300V Limited, and now out AMPS cut out.
It was originally setup with two banks using a 3 position PERKO switch (OFF + BANK 1 + ALL + BANK2), and one deep cycle Type29 battery on each bank. I added a second battery on Bank 1 (starting battery) and kept all the routing of cables the same. Stereo draws from the House battery (Bank 2) same as it did before.
The only other change I did was installing a ProMariner onboard charger for the two banks. Since I wasn't able to get out on the lake on Friday, yesterday was our first test run.
The symptoms we see happening are that the sub cuts out first if I crank the volume more than 70%, then the second amp will cut out, and last the stereo will turn off.
The amps are:
Subs - Rockford 1200.1
Mids - 2x Alpine V12 (can't remember the specs).
They were working just fine before I did the change to the battery setup and I did the charger. I made no other changes.
Any idea what I could've screwed up?
I thought of inverting the set up, using the single battery bank for the starting, and using the twin batt bank for stereo. Would this change anything?
The amps are:
