My brother just bought a 2011 Rz4 and the sub just can't keep up with the rev 10's and rev 8's on the tower. It is a factory installed Wet Sounds 10, assuming its free air. Has anybody replaced the sub, and is there room to build a box for a 12" sub in the same location. I looked in the compartment just forward of the driver and the heater core is installed there, couldn't see the back of the sub. I have an 06 24ve and have installed a sub in that compartment. Any help is appreciated before I tear into it! Thanks.
Factory install Wet sounds 10" sub in 2011 RZ4
I have a 2010 RZ2 and here is what I did! Two Free Air 10" 2ohm WS subs, wired in series and bridged on ch 5&6 on my Sinister6 amp. Thumps pretty good!
IMG_7715.jpgIMG_8227.jpg2010 Tige RZ2 "Fully Loaded" 650hrs
Surf Ballast & Enzo Bag - 1235 prop
These things need room and power. I also have installed 2 10FA 2ohm at the helm. Behind the woofers I cut a hole 9" in diameter into the wall and in doing so opened up the factory box, the woofers now utilize the entire bow as 1 big box. Mine are run in a series and are bridged on ch 5 and 6 of a syn6 wetsounds amp. Also you'll need to do some fine tuning with the gain and frequency on the amp. For just 1 2ohm 10fa just use ch 5. For 1 4ohm 10fa bridge ch 5 and 6 I believe.
Sent from my SAMSUNG-SM-G930A using Tapatalk2015 Tigé R20
