I installed a new amp and new sub all to the same wiring that was in place. I belive it is all OEM and it is 8 gauge b+ to battery selector switch and the ground goes to battery #2. It all sounds good until I turn on the ignition. There is static in them at that point and if I activate the Taps or blower vent fan it makes the bass hit. With the engine running over last weekend it had a bad hum in the speakers off the amp. I did have all the wire bundled together and found out that was a no no. I rerouted all the wiring and still having static/bass hitting. I've looked at all the grounds and can't find any issues. Anyone have ideas? Is the 8 ga wiring not sufficient? Thanks.
Stereo sounds good...until I turn on ignition.
Is the 8 ga wiring not sufficient?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
The new amp is a Lightning Audio L-4600 1200 watt amp. It is connected to (4) 6" 150 watt RMS tower speakers, and a Kicker Comp S 300 watt RMS. I removed an old Kicker comp C 12 that was hooked up to a JL Audio e6450, unknown power. The battery and switch are at the back starboard side of boat probably 13'-15' away.
With all 4 chnls running at 2 ohm, 8gs seems a little lite for a 13-15 foot run, which really equals 26-30 feet of cable. However, i dont see that being the cause of your noise. Whats the gain levels at? If this was not an issue before, then I would begin to suspect the new amp. I would double check the battery voltage at the amp and then double check the RCA connections. Maybe even get another set of RCA and just jump them from the head-unit to the amp.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I tried new RCA cables. I will check power at amp. What about one battery going out. The reason I say that is one is a year old and one is a couple years older. The noise happens with gains at all positions. Channel one and two are at 2 ohms and the bridged channel is at 4 ohms...or is this a problem. Maybe I'll throw the old amp back in and see what's up.
You've bridged a 4 ohm load across 2 chnls, so in effect, each of those 2 chnls splits the 4 ohm. That comes to 2 ohm on all chnls. What is means is the amp is working at near wide open throttle all the time.
Low battery voltage can make electronics do strange stuff.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostYou've bridged a 4 ohm load across 2 chnls, so in effect, each of those 2 chnls splits the 4 ohm. That comes to 2 ohm on all chnls. What is means is the amp is working at near wide open throttle all the time.
Any progress?
I had a similar situation with the original equipment on mine...static like "feedback" through stereo...turned out one of the RCA input cables had loosened up..on visual inspection it looked good, but when I went through each and every wire attachement at the amp...found slightly loose one...plugged it all the way in, and it soleve that problem.
Tim
Are you basing that on one amp listing its wattage output at 14.5 and the other listing the output at both 12.5 anf 14.5? If so, thats not what it means, just simply the supply voltage at which the outputs were measured. Most amps will safely run with a supply of above 16V and most will finally cut off at about 10.5.
If voltage is the root of the noise, then its a problem with your boat, not the amp. Have you tested the voltage at the amp terminals?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
