Hello,
I am planning a small stereo upgrade to my 22Ve. Couple of amps, tower speakers, pretty basic really. I think I have it cased except for the whole main wiring around the dual batteries. I have a 2 battery set up with an on/off switch only, not a 1-2-both-off like a lot of them seem to be. I am not sure how to run the main power cables from the batteries and then back to the batteries for a ground. I can't really find a good diagram of how the dual battery is set up, and how to connect the main power cables to them. In my mind, if I run from one battery, then back to the same battery for a ground, how does the isolator switch come into play? Seems like there would always be power to the amps with no way of using the switch to isolate them when the boat sits for a while. My plan is to start ripping through my boat tomorrow to trace out all the wiring and try to figure this all out, but I thought as a hail mary I'd throw this out there in case this is way easier then I am making it out to be, and somebody has a basic explanation of what to do here. I feel like I'm in over my head here but if I paid a shop to do this, the install cost would be significantly higher than the components I am putting in. And I am pretty cheap. Thanks for reading this guys, and thanks in advance for any help that can be provided.
