Adding WS420, Pair of Rev10 tower spreakers, and a SYN-4
    I have a 2014 Z1 currently with the Clarion CMD6, SYN-6 Amplifier, XS-650 speakers, and the XS-10FA subwoofer. I am adding WS420, Pair of Rev10 tower spreakers, and a SYN-4.
    I will be replacing the factory tower wiring with 12ga wire. On the SYN-6, Channels 1-2 will be used for interior speakers, and bridge channels 5-6 for the sub. On the SYN-4, bridge channels 1-2 for the pair of Rev10 tower speakers.
    From the SYN-6, the RCA cable from Channels 1&2 will go to the WS420 R&L Boat Output, RCA cable from Channels 5&6 will go to the WS420 R&L Sub. From the SYN-4, the RCA cable from Channels 1&2 will go to the WS420 R&L Tower Output.
    From the WS420 RCA R&L Input Main will go to Points 7&8 (AUX1 Input) on the CMD6.
    Attached is a few pictures of my SYN-6 amp that will need some wiring modifications done to it and a wiring diagram that I put together for connecting everything. The wiring diagram got compressed when uploading and is hard to read.
    For the remote turn on, I plan to daisy change between the SYN-6,SYN-4, and the WS420. Is this acceptable?
    For the +12V and Ground on the WS420, can I pick up off of one of the amps as shown in the wiring diagram or should I pick up 12V and Ground at the helm?
    That red AUX-IN is an input to the head unit, you want an output. I suggest the purple NON-FADE.
    Just need to move one wire and then retune the entire amp
    yes
    Yes and make sure the head-unit is also drawing from the same battery source. Do not get B+ and B- from helm.
      Got it, thanks for the help Mike!
