Current Setup: Base Level stereo consisting of two pair Wet Sounds XS-650 on head-unit and Surf Level ballast.
New Build: Wet Sounds XS-10fa under the helm to compliment the existing in-boats. The in-boat system will be driven by the new Wet Sounds HTX-6 Class-D marine 6 chnl amp. 300W rms for the sub and 100W rms to each of the 4 XS-650
Rev-8 with fixed clamps driven by the new HTX-4 Class-D marine 4 chnl for 300W rms to each Rev-8.
OEM 350 lb rear surf sacs are getting upgraded to a pair of Fly High W005 Tige Surf sacs for 600 lb net increase per side
I like the changes in the new HTX series amps. The standoffs are now part of the chassis and seem to maybe be a little higher for more room underneath the amp to hide the cabling. Controls are front mounted and under a panel. Allen tool is included for removing access panel screws.
Although we are not using one in this build, I see that the new HTX-1 now has an adjustable subsonic filter. Much more flexible for sub installs.
I have an HTX1 amp its tiny. Putting it with 2 ss-65 6.5" WS subs in my street glide saddlebags. These things are crazy small but large output also. Love the changes WS is making and can't wait for the full line of HD equipment!
Great job man... Love your work. I see you went with the HTX line of amps. What is the difference between these and the HT line? The output watts and prices appear to be pretty much the same down the line..
