Current Setup: Base Level stereo consisting of two pair Wet Sounds XS-650 on head-unit and Surf Level ballast.
New Build: Wet Sounds XS-10fa under the helm to compliment the existing in-boats. The in-boat system will be driven by the new Wet Sounds HTX-6 Class-D marine 6 chnl amp. 300W rms for the sub and 100W rms to each of the 4 XS-650
Rev-8 with fixed clamps driven by the new HTX-4 Class-D marine 4 chnl for 300W rms to each Rev-8.
OEM 350 lb rear surf sacs are getting upgraded to a pair of Fly High W005 Tige Surf sacs for 600 lb net increase per side
I like the changes in the new HTX series amps. The standoffs are now part of the chassis and seem to maybe be a little higher for more room underneath the amp to hide the cabling. Controls are front mounted and under a panel. Allen tool is included for removing access panel screws.
Although we are not using one in this build, I see that the new HTX-1 now has an adjustable subsonic filter. Much more flexible for sub installs.
