Saw this on another forum....
Here is a quick rundown. The Media Center is a black box brain unit with master full color display and ability to have 3 transom remotes.
AM/FM/weather band, aux Input, Usb with Apple and android support, Bluetooth 4.0 with CSR chip with APTX codec, Sirius/XM ready, Pandora ready, Spotify Ready (so if your streaming pandora, all information and cover art shows up on the screen and you can thumbs up and down from the unit)
4 zones of 4 volt RCA outputs. All uclipped at max volume for easy system tuning and clean signal no matter what! All 4 zones can be re named, Tower, Boat, Sub and Bow for example. Master Volume with seperate easy access independent zone control. So yes like a 420.
Ability to preset 3 volume profiles and name them. Wake, Party and Chill for example. Set towers at 100%, sub at 75%, boats at 50% and bow at 25% and then save that profile as "wake". Master volume will then track volume up and down but will not go past % setting for each zone. Example: tower is 100% so master volume will track that from 0-100% of the volume and reach 100% when radio is on max level of 40. Boats are set at 50% so master volume will track 0-50% for this zone. When master is at max of 40, boat zone will still be at 50%.
Once you play with it, it is the easiest way to control audio and zones you will find. And the only radio that will allow you multiple pre set profiles.
Also, has the ability to have 3 quick pre set fast access sources, so you select you favorite 3 sources so no scrolling through complex menus.
We designed the GUI to be clean and simple, easy to use, large knob, full color
Also, transom remote has all zone controls as well and you can change zone volumes in one simple click of the large knob.
We plan on having everything in production by the end of the year as we have finished tooling and finializing a few more software and GUI parts.
So end of first quarter for availability.
Tim
Wet Sounds
Tim
Wet Sounds
