We are installing an exile xi12 sub. The box you see below is 1.14 cu ft and we plan to install it below the heater in our '07 24ve, in the compartment in front of the drivers seat. The box is 3/4" mdf and will be soaked in epoxy, carpeted and mounted on the floor below the heater. I also plan to put a thin sheet of HDPE below the sub to keep it off the floor. How important is it to seal between the sub box and the bulkhead wall in front of the drivers seat? Will the carpet cut well using a jigsaw or should I cut it out with a knife before cutting the bulkhead? Any other tips or troubles spots you see brewing?
