Noise From Speakers
    Noise From Speakers
    Noise is present with the head unit on along with any other accessory regardless of which mode (haven't tried a cd). Usb is very slightly less noise than Bluetooth and tuner maybe slightly less yet.
    The noise is a buzz, varies slightly in tone with which other things are on in the boat, fuel pump, ballast pumps, etc.
    All power is tied to distribution blocks that go to the amps, the blocks then run directly to the battery switch and battery 1 for neg.
    Yes tried a couple other rca's.
    Do I need to make a diagram to explain the setup perhaps?
      Check your connection at block. Sometime this is corroded and becomes a poor ground.
      Kaotik Kustomz: WetSounds, Arc, Kicker, Focal, Masconi, Sony, Kenwood, Pioneer, MTX, Life Form, Lumitec, Shadow Caster, Fly High, Llumarr, Sun Tek, SolarFX....
