Will 4 REV 8 speakers fit on a 2015 Tige R20 Vector tower?
4 REV 8 on vector tower???
placement.jpgyes...yes they will!
If you don't feel comfortable stacking them all together on the top horizontal bar then put one on the top and one on vertical bar.
The picture will help
Thanks for the reply. By looking at the 2 speakers that are already installed and the pre drilled holes for (I'm guessing) the second pair would seem to close together. There does not seem like enough room for them to fit side by side. The set already installed are maybe 2-3" on the inside of the Bimini bracket and the pre drilled holes are about 2-3" on the outside of the Bimini bracket. Hoping to see a set of 4 pre installed to get a better idea if I would have to reposition the outside set to make them all fit. Can't move the 2 inside speakers in any further as the are already a bump hazard.
From a physical mounting standpoint, I do not see why those four 9" dia pods will not fit. The location and spacing may differ than what the factory had in mind.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Curious if anyone with 4 Rev8/10s has had any issues with cracking on the vector tower? Reason I ask is it seems the E-series tower had many issues cracking when 4 speakers were added. I know the design is a bit different but the material is the same. The side to side shifting of the tower while trailering long distance, or running on rough water seemed to crack my E series. It seems like the alpa Z is the ultimate tower for multiple speakers that is so far, if they could just figure the leg bolt mechanism out that is, so it doesn't strip or over tighten and crack the expensive legs!!
