Boat came with:
3 pair Wet Sounds XS-808
XS-10FA
Driven by SD-6
2 pair Rev-10 with RGB rings
Driven by SD-2
Wet Sounds RGB LED Music Controller
The plan:
RGB rings on the 6 XS-808
2 Kicker Comp-VR10 Subs bridged on the current SD-2 and will split 1250W rms. One in the OEM spot, and the 2nd is a smalled sealed enclosure tucked away in the port mid-ship locker.
Adding a 2nd SD-6 that, in conjunction with the existing SD-6, to drive the 4 Rev-10 @ 585W rms, as well as the 808's as they currently are
WS-420SQ with the in-dash mounting plate.
2 pair Suitz-10 speaker covers.
Pulled the factory sub out and was very surprised and pleased with what I found. The sub cavity is nearly finished. With a little caulk and expanding foam, I think this cavity can be sealed up air tight. Unfortunately, There is not enough height to the seat base to house a 12" sub.
More to fallow.
XS-10FA
Driven by SD-6
Driven by SD-2
The plan:
More to fallow.
