stereo has been working fine, but now it seems like the tige touch wont clear it self it thinks its connected to a devise, but when you try to connect your iphone to it, it just says that it cant find the device. i tried to turn the main power off on the boat hoping it would reset it but still seems to be locked up. anyone run into this
2013 z1 with bluetooth issues
I would dump any stored paired devices from your phone, then start over.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I run into this problem all the time on my 2013. I always have to click on my phone to "forget device" and start over(this seems to work the best). Also I tend to turn the blue tooth option off on the tige touch and wait a few seconds and turn it back on which seems to help sometimes. I have gotten irritated plenty of times with the Bluetooth function but until I get a new iphone I cant confirm that my iphone isnt the problem
It seems that Tige is using the same Medallion BT unit as Malibu, last I heard, they were up to something like Rev-J trying to resolve issues.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
IIRC, it was replacement units, not an update.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostIt seems that Tige is using the same Medallion BT unit as Malibu, last I heard, they were up to something like Rev-J trying to resolve issues.
When switching devices we usually have to turn the BT off of one before we pair the second. PIA but I have not had an issue since this little work around.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Had to go in and delete the paired device from my wife's iPhone after that, i turned the power of on the main switch in the back of the boat. turned it back on after about 5 min and it fixed the problem. Have been on vacation this week and to have a place that you can ask questions and get the help needed to fix these small problems is priceless!!!TIGE #bestboatihaveeverowned
Originally posted by GBNY View PostHad to go in and delete the paired device from my wife's iPhone after that, i turned the power of on the main switch in the back of the boat. turned it back on after about 5 min and it fixed the problem. Have been on vacation this week and to have a place that you can ask questions and get the help needed to fix these small problems is priceless!!!TIGE #bestboatihaveeverowned
[ATTACH]38313[/ATTACH]
trying to get mine to connect. It just keeps the in progress going then when I try to click on it it says disconnected. I do have a lot of blue tooth items on my phone maybe I need to clear them all and start fresh. One thing on the Tige touch there is a blue tooth for jakes phone. Previous owner and it will not forget it. How do I get this thing to forget a phone?
JaredW-00 if it won't forget previous you need a software update and it will fix your issues
Sorry for dropping the ball on your o2s. If you need rhe software update I should be able to get it..as long as Salesforce is still up
Just to be sure if I do send software....you DO NOT have a Polk head unit in the glovebox correct?? Everything is on the screen for stereo??
No Polk head unit everything is on the touch screen.
Originally posted by freeheel4life View PostJaredW-00 if it won't forget previous you need a software update and it will fix your issues
