Yesterday I started connecting all of the RCA's and such to now run my WS420 EQ. I haven't looked in to it further yet but now my sub doesn't work and as I already knew would happen I have lost the control of the volume at the deck and secondary control on the drivers side. I used the purple RCA's out of the back of the deck to the 420. Should I have used a different set to be able to control the volume though the deck? I could use just the 420 but I'd rather use the control up top as it's right by the throttle and the 420 is mounted lower under the dash. It already sounds so much better than it did prior the only other thing it needs now is a proper tune which I have a friend who is in the industry that I will have come by to do that. My only complaint in all of this is I wish Tige would have raised the speakers off the ground and put them in the sides where the cup holders are as I think it would help drive the sound better although I'm sure everyones ankles appreciate the music.
