speakers wit LED question
    I'm on a bit of a budget and was thinking about getting some Kicker speakers with LEDs in them. Does a seperate power wire need to be ran for the LEDs? Thanks.
    Get ahold of chipthrl he's the boss when it comes to that stuff I know that the Wetsounds you have to run extra wires but not sure how kicker does there's.
    surf till u die.
      Yes, the LED requires a switched B+ and B- thats separate from the speaker leads.
        Thanks. Does it require a transformer? Or can I go straight to the battery? Can I wire them in series?
        Sent from my XT1080 using Tapatalk
          Do you put the LED controller at the amp rack? If this is the case is it better & cleaner to run like a 12-4 speaker wire? Or should the power be ran separate?
            The Kicker controller is RF, so it can be mounted just about anywhere. I would not run 12/4 for the speaker and LEDs for a couple of reasons. 12ga is overkill for an in-boat, 14ga is even more than enough, 16ga is probably just right foe a single 6.5" in-boat with moderate amp wattage. For single color LEDs, I typically run a 18/2 starting at the furthest LED and loop around the boat to where the controller/switch is going to be. All LEDs are wired in parallel as they are installed. For RGB, I use 22/4.
            The speaker wires for the driver and LEDs are entirely separate circuits.
