Well I got it all in and wired up only to find out that for some reason the RCA plugs on the head unit do not work. The other three pair on the head unit are occupied - any thoughts on why the 4th set of RCA's will not work? I plug the RCA into an open set of ports on my tower speaker amp and it works.
Not sure if that is the right way, but did not want to use the high level connections. Any suggestions? Not sure what model clarion head unit is in - came with the boat (2012 rz2). As far as sound goes it sounds pretty good and complements the free air sub nicely. I could not turn it up a ton, but it had a nice punch under forward observer compartment.
Sent from my iPad using Tapatalk HD
