I have an RZ2 with two Rev 10 Speakers, but one of them has com loose and is bouncing around... quite a bit. Simple Question: How do you install / remove those? I have tried to go in through the driver, but I can't get it out for the life of me and I am scared I will break something... Some Pictures would be GREAT!
How do you Tighten Rev 10 Speakers on Z Tower?
4 screws to remove the grill, 4 more from the driver. Next step is the tricky one. The driver is a very snug fit into the pod. With one hand bracing the driver, use the heel of your other hand, pop the outside of the pod in a couple of spots around the pod to jar the driver loose. Once it comes loose, pull straight out until you can disconnect the woofer and compression driver wires. Now you have access to the 2 mounting bolt.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
