Xxx12 sub boxes
    Xxx12 sub boxes
    I currently have a rz2 My question is this the sub box dimensions on Wetsounds web site is awesome info but I'm wondering if anyone has had any issues fitting these boxes in there rz2 I'm 250 miles away from my boat and was thinkn of building them in advance but am a bit worried il have to do some modifications if I go that route. Any info would be greatly appreciated thx
    surf till u die.
    I think Tim W. designed that box specifically for the RZ2 but I might be wrong.
      Here is Houstonshark's XXXv2 install in his RZR. It will give you an idea of what its going to take to fit that box under the helm. I would suggest designing the enclosure to fit the boat as opposed to building a box and then making it fit into the boat. With a ported enclosure, the 2 most important factors are the internal volume and the port volume. To a degree, the H x W x L is not as important. They will be determined by the other numbers and can be manipulated in order to make the enclosure work where it needs to.
      http://www.tigeowners.com/forum/show...Under-the-Helm
        I build the box on the website and it was to big for my z1. Originally built it for my old 20v but I sold it before I installed it. Now it just takes up space in my garage.
          I didnt want to deal with moving the electrions up, and have that dual slotted box not fit. I measured and looked at it alot, and it didnt look like there was room. So i went with the other box they have on there web site.
            Is that the xxx sub What she said
            surf till u die.
              18c racing, yes its the older XXX from about 2 years ago. Im pushing it with a SYN1, and its impressive. Its crazy how much bass you can hear out side the boat at the beach. I also have 2 paris of REV10's powered by an SD2, and its a very good balance.
                SUB2.jpgSUB1.jpgMore pics.
                  Not sure what happened to most of the pics in my thread but I still have all I them. Let me know if there is anything you want to see from the enclosure, helm wall or trim panel.
                    How close to the front ballast does it go. I'm just tryn to get some feedback on box sizing that sounds awesome any input would be awesome thanks
                    surf till u die.
                      I have the smaller U shaped 400lbs sac up front, and the enclosure is about 6-8" from the sac. Some room for storage on my setup. I keep 2 small tool boxes between the box and the sac. If your boat has the surf ballast (2x 400lbs sacs) the box would prob need to be touching the ballast.
                        pic
                          The picture turned on me, sorry. It doesnt show the sac in the pic, but im sure its just out of sight. I hope this helps. What ballast system do you have in yous?
                            Pro ballast. But the pics help a lot thx bud
                            surf till u die.
