Help with placing XS-650s in an old RZ4
    I just got an ’08 RZ4 with a weak weak little stereo. Due to the bad influences of other forum members (YOU guys know who you are….), I bought (4) Icon8s and (6) XS-650s powered by a couple of Kicker’s new line of marine amps. And of course I had to get a bunch of RGB LED rings
    The boat currently has only (4) inboats and doesn’t have the now typical upper backrest inset area for the inboats.
    And my question is where to put the third set….
    Should I put one down towards the front end of the long panel under the port side seating?
    Can the other one go on the opposite side panel under/in the lockable storage area?
    And are the LED rings going to fit around these inboats? Looks pretty small – I plan on just leaving the old tweeters as filler for now.
    Sent by the random thoughts from the voices in my head... Eric
    I added one pair of 6.5's, and relocated one of them on my 2011 RZ2.
    I moved the one at the driver feet to behind the shifter.
    The two i added= one is mounted on driver seat base firing to the passanger side, and the other is mounted on the passanger seat firing at the driver.
    The boat was lacking sound at the passanger seat, and the driver need more sound after upgrading subs.
      Where does the boat need sound? Thats how i made up my mind.
        I don't have the luxury of knowing where the boat needs more sounds as the current four inboats and dbot5 towers are grossly underpowered and lacking a sub.
        I like the idea of behind the shifter.
