Over the weekend I was working on installing my second amp which will power my 4 in-boat speakers and a sub. I had an existing 2 channel amp that power my tower speakers. Long story short I got done installing everything at the dock so I decided to take the boat for a spin and really crank it up in the middle where I wouldn't bother anyone. The speakers sounded great now being powered by an amp - I gave them a good workout and played with frequency and levels.
This is where my problem arises - currently I have a PAC LC-1 in line with my tower speaker RCA's. I noticed that the knob was not stopping at the typical low and high hard stops last week, so I ordered a new one and had planned to replace it this weekend. I did not replace it soon enough though... My tower speakers were all the way turned down (using the LC-1) and as I turned the dial up slowly I heard a popping noise coming from where my amps were mounted. The tower speakers were working, but I was getting some strange feedback and they were cutting in and out. I looked in the compartment where my amps were and the tower speaker amp appeared to be almost shorting out - it was flickering on and off and then POOF, I let some magic smoke out the top of the amp. I scrambled to cut power to the amps and shut the system off. The speakers had worked fine when I was at the dock, but I did not not adjust the LC-1 at all when powered up.
So was this just a coincidence that my amp decided to die as I was adjusting the RCA level, or did the LC-1 cause some sort of short and fry something in the amp? I am not too familiar with RCA's and what type of voltage/current is being transferred so I need a little insight. I unplugged the RCA's from the amp once I had the boat back on the lift and powered everything up. No smoke and no protect lights. Help...
