OHMS
    OHMS
    MY TOWER HAS A PAIR OF 6.5 DBL END BAZOOKA-100RMS EACH@2OHMS
    IM ADDING A PAIR OF6.5 COMPRESSION HORNS BAZOOKA-150 RMS EACH@4 OHMS
    I HAVE A BOSS AMP 100X4RMS@4 OHMS
    CAN I MIX OHMS?IM CLUELESS.SHOULD I RUN NEW 14 GAUGE WIRE TO EACH.CAN I JUMP A WIRE OFF DBL END LEFT TO COMP HORN LEFT IF EXISTING WIRE IS 12 GAUGE?ALL I KNOW IS FROM THE THREADS IVE READ FOR THE LAST 6 MONTHS.THANKS FOR HELPING.IF I HAVE A WS-420 ON DRIVERS SIDE.HOW MANY RCA'S DO I NEED FROM STORAGE TO DRIVERS?WHAT OTHER WIRES NEED TO BE RUN?
    CLUELESS IN CALI!
    ST,
    In principal we can wire multiple speakers together, even if they have a different nominal impedance. In your case, you are working with three 4 ohm speakers in two pods. The DBL is two speakers wired in parallel (+ to +/- to -) so to = a 2 ohm load. Amplifiers are designed to work within a designed impedance (speaker load), so we have to work with in that range in order to have the amp run happy. If we apply a load outside of what the amp can handle it will run hot and in most cases, drop into a protect-mode. In a worst case, it will cause the amp to eventually fail. So, with your given scenario, your only workable configuration would be to wire the new speaker in series with the existing 2 ohm DBL. This will net you a safe 6 ohm load at the amp.
    Two things happen at this point. 1) the amp's output drops considerably at 6 ohm. 2) Each speaker wired together on a an amp chnl shares the available power. In a series/parallel config, the 3 speakers do not divide the power equally, especially when you have dissimilar speakers like a pair of coaxial and a single HLCD.
    In your case, I would suggest leaving the 2 ohm DBL's on the amp chnls they currently occupy, and wire the new HLCD's to their own amp chnls. This can be accomplished with either two 2-chnl amps or a single 4-chnl amp. The trick to a single 4-chnl amp is going to be finding one that will supply ample power to the 4 ohm HLCD's without overpowering the coaxial 2 ohm DBLs. Both JL and Alpine have some amps that produce the power per chnl at both a 4 ohm and 2 ohm.
    Alpine PDX-F6 comes to mind with 150W x 4 @ 2 or 4 ohm or the JL HD600/4 with the same specs. Depending on your budget, you may find a pair of 2 chnl amps for the price of either of these, but you cant beat the quality.
    What amp do you currently have and where were you intending to use them? You may be able to utilize one for one pair of tower speakers and then pick up a 2nd to power the other pair.
      I HAVE A JBL MA6004 60X4RMS(ORIGINALLY BOUGHT FOR INBOAT-4 OR 6 BAZOOKA 6.5'S)BUT WHATEVER YOU THINK I SHOULD RUN I WILL.
      BAZOOKA 2X30 RMS MAYBE FOR 2 OF THE INBOATS?I REALLY HAVE NO CLUE.IJUST KEEP READING ALL YOUR INFO AND TRY TO SORT IT ALL OUT.PICS OF ETS 2012 IS HELPING ALOT.THANKS AGAIN FOR YOUR HELP.AND I READ SOMETHING ABOUT COMPRESSION HORNS SHOULD BE 8'S OR BIGGER TO GET THE MOST OUT OF THEM SO I ALSO WANT TO AND BAZOOKA 8 COMPRESSION HORNS BEFORE NEXT SUMMER.
        Honestly, if you want to best utilize the new HLCD's, run them bridged on that JBL MA600.4. This will deliver 160W rms to each, which is what they need.
        What model Polk sub do you have? let me look into how best to use the Bazooka 2 chnl and the Boss 4 chnl. The above may change.
          I BELIEVE ITS A DB10-40DVC.I HAVE READ ALOT ABOUT YOU SAYING TO GO WITH A 12"IN A BOX BUT ITHOUGHT I READ THAT IT WONT BE GOOD FOR MY 99 2100i under helm cause of batteries.any idea would be great i like more of the punch bass than other.what you said about jl i like that idea.then leave dbl end on boss amp with sub running off that also?my hu is boss with 80x4 could that be used on inboats or not enough(4)bazooka6.5and other bazooka amp for 2 more bazooka 6.5?im asking cause i dont know just pretending to know.DO i still need to run 12 OR 14 gauge up the tower for the comp. horns.i started ordering random kicker amp kitsPKD4(09PD4),rca's 2 CHANNEL,y's 1 MALE TO 2 FEMALE,tsunami FDB9002M-MANL.BOUGHT BY LOOKING AT PICS OF YOURS IN FORUMS GUESSING WHAT MODEL#.THANKS AGAIN FOR ALL YOUR HELP.SURE YOU DONT WANT TO START A NEW BOAT STEREO BUSINESS IN CALIFORNIA?
            Originally posted by ST.TIGE View Post
            I BELIEVE ITS A DB10-40DVC.I HAVE READ ALOT ABOUT YOU SAYING TO GO WITH A 12"IN A BOX BUT ITHOUGHT I READ THAT IT WONT BE GOOD FOR MY 99 2100i under helm cause of batteries.any idea would be great i like more of the punch bass than other.what you said about jl i like that idea.then leave dbl end on boss amp with sub running off that also?my hu is boss with 80x4 could that be used on inboats or not enough(4)bazooka6.5and other bazooka amp for 2 more bazooka 6.5?im asking cause i dont know just pretending to know.i still need to run 14 gauge up the tower for the comp. horns correct.i started ordering random kicker amp kitsPKD4(09PD4),rca's 2 CHANNEL,y's 1 MALE TO 2 FEMALE,tsunami FDB9002M-MANL.BOUGHT BY LOOKING AT PICS OF YOURS IN FORUMS GUESSING WHAT MODEL#.THANKS AGAIN FOR ALL YOUR HELP.SURE YOU DONT WANT TO START A NEW BOAT STEREO BUSINESS IN CALIFORNIA?
            Ok, let me look up that sub in the AM, as my weekend has started already
            yes, a sub in a box always trumps a free-air sub. But when done correctly, an Infinite-Baffle sub can yield good results and some boats are perfect candidates for an infinite-baffle sub without some drastic mods.
            Yes, the in-boats could be powered off the head-unit, but realistic wattage will be more like 15-18 watts rms. You would be better served to feed them with some amplified power.
              IS 14 GAUGE WIRE TO BIG TO RUN FOR 6.5'S?I HAVE A ROLL AND WANTED TO JUST REWIRE THE BOAT 1 TIME RIGHT.COULD I DOUBLE THE WIRES OFF THE HEAD UNIT TO RUN 1 SPEAKER OR 1 PAIR OR EVEN WIRE ALL 4+ AND ALL 4- TO JUST 1 BAZOOKA 6.5 SPEAKER UNDER HELM NEXT TO SUB
                Im not following exactly what your are saying, so I try to answer in a way that may help you.
                1st) 14ga wire is perfect for an in-boat speaker.
                2nd) If you are going to power the 4 in-boats off the head-unit, then each speaker needs its own 2-conductor speaker wire making a home-run from the speaker to the head-unit.
                  SORRY TO BE SO CONFUSING.YOU MENTIONED MY HU ONLY PUTTING OUT 15-18RMSX4.I WAS JUST WONDERING IF YOU COULD DOUBLE UP WIRES TO GET 30-36 OR PUTTING ALL 4 HU WIRESTO GET 6O WATTS.TRYING TO FIND USE FOR HU POWER.IT WOULD BE NICE TO POWER 1 6.5 UNDER HELM OR ALOND SIDE DRIVER WITH WASTED WATTS.
                    Lets start with the Polk woofer. Polks website indicates that the DB1040DVC is best suited for a sealed enclosre with a net volume of .66cu/ft. The manual actually states running is infinite-baffle voids warranty. I cant find the woofer's displacement, so id say that if the enclosures gross volume was .85-1.0 ft3, you would be good.
                    On your boat, building an enclosure either means move the batteries to the port locker or loose leg room under the helm. To maintain an infinite-baffle install, you would do best to replace the polk with a sub thats better suited for it.
                    Now, lets say everything, amps and speakers wise, is going to stay as is. Here is how I would configure it:
                    As noted earlier, run the new Bazooka 6.5 HLCD's bridged on the JBL600/4. This would net them 160W rms.
                    Run the 4 in-boats on the Bazooka CSA-2. This would net each about 25W rms each. Port pair wired in parallel on chnl 1 and starboard wired parallel on chnl 2.
                    On chnls 3/4 of the Boss MR1000, I would run the Polk bridged. The 4 ohm DVC sub will need to be wired in series, so the bridged load is 8 ohm. This nets a 200W rms for the sub.
                    On chnls 1 and 2 of the Boss MR1000, I would wire each Bazooka 6.5 DBL to its own chnl. This will net 250W rms to each pod. This is VERY strong power for those Bazookas, so tuning is crucial.
                      No. The internal amps on a head-unit will not allow for this. They can only run as individual chnls with a minimum impedance of 4 ohm.
                        THANKS AGAIN FOR ALL YOUR HELP.IM GOING TO ADD ANOTHER BATTERY, ACR AND PROSPORT 12 (OR WILL PROSPORT 20 WORK WITH 2 BATTERIES)CHARGER IN HELM COMPARTMENT.SO WHAT SUB WOULD YOU PUT THERE?I SAW PICS OF A JOB YOU DID "JASONS 21.I STEREO & LED BUILD" 7-29-11 PAGE 7 IN THIS FORUM,BUT I COULDNT TELL WHAT WHITE SUB IT WAS?OR IS THERE ANOTHER YOU WOULD SUGGEST THAT YOU THINK IS BETTER?NICE JOB ON HIS BOAT!THE BOSS AMP IS ALREADY IN STORAGE COMPARTMENT SO I WAS JUST GONNA LEAVE IT THERE AND PUT THE OTHER TWO THERE ALSO OR WOULD YOU SUGGEST PUTTING ANY IN BATTERY/HELM COMPARTMENT OR ALL?WHATS BEST?IT LOOKS LIKE 1 IN EACH ON JASONS.WHAT WOULD YOU DO IF IT WERE YOUR BOAT?
                          On Jason's 21i, we used the Wet Sounds SW-10FA. The "SW" series the the closed Sportsman series and the "XS" is the silver spoked grill. Same subwoofer, just different look and grill.
                          Other infinite-Baffle sub worth mentioning.
                          Alpine SWR-M100
                          JL M10IB5
                          Kicker CVR-10 (not specifically designed for infinite-baffle, but does well)
                          JBL MPS1000 Self-powered sub (have no actual experience with)
                          Theres plenty of room for 3 amps and an amp rack, on the outside wall of the port storage locker. Doing a 3 amp install from nearly scratch, this is where i would mount them.
                            I BOUGHT THE JL HD600/4 LIKE YOU SUGGESTED AND ALSO THE JL M10IB5 LIKE YOU SUGGESTED.WHILE PUTTING MY AMP RACK TOGETHER AND WENT TO START WIRING AMPS AND DIST. BLOCKS TOGETHER WHEN I SAW ON HERE THAT I MIGHT NEED A SMALLER FUSE IF I WAS RUNNING 3 BIGGER AMPS AND THEN 1 SMALL 2 CHANNEL.(I THINK IT WAS ON PAGE 12)IM SO OUT OF MY LEAGUE.I BOUGHT THE KICKER AMP KIT WITH WIRE ,FUSE,DIST BLOCKS AND ALSO TSUNAMI FUSED 1-4GAUGE---2-8 GAUGE DIST BLOCK.MY OTHER 3 AMPS ARE JBL 600/4,BAZOOKA CSA-2,AND BOSS MR1000/4.MY BATTERIES ARE IN HELM COMPARTMENT.DIST.BLOCKS ON AMP RACK IN OPPOSITE STORAGE.WHAT IS THE PROPER WIRE GAUGE?THIS KICKER PKD4 HAS MORE 8 GAUGE THAN I THOUGHT I SHOULD BE USING BUT I HAVE NO CLUE.THEN COMES RCA'S NEXTCHP THANKS AGAIN FOR ALL YOUR HELPWHAT SIZE SHIRT DO YOU WEAR?ITS THE LEAST I CAN DO.
                              ONE OTHER QUESTION.DO YOU THINK BAZOOKA 8'S OR 6.5'S WOULD BE BETTER IN MIDSHIP WALLS.THE 8'S WILL FIT BUT WHEN YOU INSTALLED THE 880'S YOU MENTIONED THAT THEY WERE OVERPOWERING THE SUB.WHAT WOULD YOU DO CHP?OR WOULD I JUST AD ANOTHER JL SUB NEXT TO THE OTHER ONE LATER IF THIS IS A PROBLEM.JUST WANT TO DO IT RIGHT THE FIRST TIME.THANKS AGAIN FOR ALL YOUR HELP.
