promariner and tigetouch
    anyone installed a pro-mariner or pro-sport battery charger with the tigetouch system? anything different I should know about adding an onboard charging system? want to put one in this boat but don't want to fry the electronics, however also don't want to have to unhook a bunch of battery cables each time I want to plug it in..
    thoughts?
    2012 22ve.. RIP 4/17
    2014 Z3.. Surf away
    The Promariner should not pose any problems for the TT. You will not need to disconnect anything during charging, especially with the Dual-Circuit switch in the off position.
      cool. one more thing to add to the list to order and install
      2014 Z3.. Surf away
        Just installed mine Tuesday. I always put the battery switch to off when pluging in the charger/maintainer, so there should never be an issue. FYI, they make a 2-bank system that's 8" wide, 7 1/2" tall, and 2 1/2" deep that can mount right beside the batteries. It's waterproof, & will work with any style battery. I paid $130, & it took about 15 minutes to install.
