Originally posted by Bruizza
View Post
tower speaker decision
4 Rev 8s and a syn 4. If that exceeds the budget 2 rev8 and a syn2 will do the trick as well. Or go nuts and get Some Rev 10.. I went with the 8 to keep as much headroom as I could.But since your not looking to be "The" guy 2 8s is nice and 4 is crazy loud.IMPO Good luck...your looking at quality stuff and cant really go wrong with either so either way enjoy!
Originally posted by Zerps View Postso would one harpoon amp provide enough power for 2 xm7's, a 12" sub, and 4 in-boats? (knowing of course 2 dedicated amps would be more power and possibly better sound, but cost is also an issue)
If cost is a concern, there are cheaper amps then the Harpoon that will deliver same or more power and are more efficiant.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Supreme Tigé Master
- Apr 2007
- 12007
- Lake Carl Blackwell, Stilly, USA
- 54 Bellcraft, 56 Burchcraft, 61 LoneStar, 75 Catalina 27
Originally posted by majestic View PostI have a cooling fan. It was $34.00 much cheaper than a second Harpoon
Is there any shroud or other device that is not shown in that pic that helps direct air over or around the amp? Don't take this wrong; I am friends with all the manufacturer dudes, and maybe it is a bad picture angle, but what I see in the pic kinda reminds me of someone shaking an empty salt shaker over a bag of movie popcorn. Probably a bad analogy but I am curious...
I only bring it up because lots of guys could benefit from increased air circulation. How is your fan system set up? I could only guess that somehow there is a hole behind the fan pulling air from under the amp out of some sort of cutaway cavity maybe?
If it works well we ought to know what you did! Share?
Phil
KickerIt's not an optical illusion.
It just looks like one.....
Phil
Kicker
I doubt you will find anything earth shattering in the execution but I have run it hard in the heat and experienced none of the issue mentioned above.
Happy to hear any of your advice/suggestions.
