Got an interesting one for you guys.
Hooked the boat up to the fake-a-lake to prepare for the first trip out this season. While doing so I thought I would take advantage of being able to listen to my stereo.
Crank the boat, turn the radio on, and I start listening to a local radio station while I start to clean the interior of the boat, no high pitch noise (hasn't presented itself yet). Realized I had my iphone in my pocket I hooked it up to the ipod / iphone adapter that I installed last summer. Instantly I heard a really HIGH pitched frequency. The iPod adapter connects to the satellite adapter. It's not a hum.
The adapter I have:
The box that my adapter is plugged into. I have it plugged into the Pass-Thru:
Things that I did / tried to kind of troubleshoot it a little bit.
My head unit is the Clarion CMD5.
- Upped the RPMs on the boat to see if the pitch would fluctuate. NOPE! The pitch of the noise was constant.
- Switched from my cranking battery to my deep cycle batter. High pitch noise is still there.
- Turn the boat off and the high pitch went away (radio is still on).
- Cranked the boat again, and played all the audio sources I have available (CD, local radio) No high pitch noise.
Not real sure what it might be, but I wonder if it has to do with the clarion sirius box, or maybe the head unit isn't grounded to the same ground as my amps and EQ, or maybe its my iphone. I am going to hook up my iphone to the EQ with an 1/4 inch to RCA adapter tomorrow to see if I get the same high pitch. This might be my workaround.
Thoughts... Ideas? Like I said it's a constant high pitch. It's not a hum like you would get if you had a bad ground, or were picking up engine noise.
The adapter I have:
