spring project
    spring project
    added four samson SMT65's to the tower with the four samson S9HD'S and another samson harpoon amp, and three kinetik's, the sound is unbelievable, you can here them from over 100 yards easy.
    sincity
    2005 24v
    Wow I bet that is an understatement, they look great on there
      Very nice!
        Again, WOW!
          DAMN!!!
            INSANE!
              What else do you have in that boat? That's a lot of amps for some tower speakers! Looks great!
                There are a total of twelve component speakers, 8 JBL MKII's rated at 150 rms, which are driven by two 1000 watt Samson harpoons, and then there is one pair of the Rockford fosgate 8 inch marine coaxial's and one pair of the JL audio marine speakers up front, which is driven by a exile 800.4, there is one FI audio 15 inch subwoofer which is being driven by a exile audio 2500.1 which is absolutely ridiculous, it will make the water bubble, the sub is built here in las Vegas. All the amps are oversized by about 40% which allows for efficiency ratings, heat loss, and voltage drop, heat loss is a killer on lake mead in August,figuring all this in allows for all the component speakers to receive there full RMS ratings. The sub woofer however will take every watt the 2500 has to give and seems to want more. I have two bilge fans set up in a push pull set up, for amp ventilation.
                Sincity
                2005 24v
                  WOW! mega boat-boom-box is understatement.
                    Attaboy! You will be even louder and cleaner than at the reunion last year!!!
                      My ears have started to bleed just looking at that setup. What a clean, good looking setup you have.
                        Thanks guys, we will be at lake mead this Sunday the 29th, meeting at calville bay at 9:00 am, come on out
                        2005 24v
                          who did the stereo? I would like to have that in my arsenal, getting lots of calls about aftermarket sounds, but want to have a local contact.
                            I did the install my self, I have about 30 years experience in the electrical and electronics field here in Vegas.
                            Sin city
                            2005 24v
                              Sin city
                              you forgot to add that your charge to install in someone else's boat would be ONE MILLION DOLLARS.
                              That install is crazy clean SC (though I can't believe you didn't line up all the speaker grilles, I mean c'mon! ). Looks awesome.
                              Do you rock it at full tilt a lot?
