Originally posted by chpthril
View Post
Fun With LEDs
Originally posted by topaz surfer View PostDo you stock them and what are the colors and prices if you do?
They come in Blue, Red and White and the bezel is white and chrome. Requires a 2" mounting hole and the OD is 2.75". 4 LEDs and the lens is frosted.
$20.00 ea.Attached FilesMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostI do not have any in stock at the moment, but can usually have them is a couple days.
$20.00 ea.
Originally posted by topaz surfer View PostThanks mike I might get some of those from you. I just need to decide if I want to go that route or go for the speaker grill leds. Im assuming I could tie them into my existing courtesy lights?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
2012 Malibu 23 LSV Phase-1
Nothing too exciting, I just thought the green came out killer
Interior:
8 6.5" in-boats with rings
1 12" sub with a ring and puck in the grill
16 cup holders with rings and a puck in the center
rear "Wakesetter" emblem back-lite with an acrylic block
strip in the drivers storage pocket
Side "Wakesetter" red led strip replaced with green and pulled off the courtesy circuit and placed on the green led circuit
Exterior:
two forward vent and two aft vents
Under water:
two Shadow Caster SC-10's in green
The underwater lights are run through the Maliview, the exterior LEDs have a dedicated switch as does the interior.
Phase-2 will be 2 pair of Rev-10's on an SD-2, both with green LED rings.
Thanks everyone, I hope you'll enjoy the pics. Ive got a Chap coming in Sunday that's getting all RGB's that will be on a controller that interfaces with the music.
2 Sea Blaze-3 in white
2 Rev-10 light rings
8 XS-650 with rings and pucks behind the tweeters
3 cupholders with rings and pucks
and then some miscellaneous RGB strips here and there.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
More Fun With LEDs: Scientific Test!
Ok, not really anything scientific, just having fun
My son is kicking around the idea of doing some LEDs on his snowboard for this coming season. He wanted to see how long some LEDs would last on a 9V battery. This would be small and easy to wire to the side of his boots. So i told him to just take a roll and and wire them to a battery and see.
One brand new dollar store 9V
one 16ft 300 LED single color strip of LED
We hot-glued the wires to the battery and wire-tied the battery to the spool. he took it home with him so he could keep an eye on it and note when it died.
Well, this pic was taken exactly 24hrs later! It was noticeably dimmer, but still glowingIt finally died at 60hrs.
Amp draw and this 16ft 300 LED roll is 1.4 amps. The amp draw on a 16ft 300 RGB roll with all 3 colors lite was 4.6A.
