How to open REV 10s
    How to open REV 10s
    What is the trick?
    Four screws out, grille removed.
    Four additional screws out, ready to pull the speaker...
    It is in tight and prying with a flat screwdriver is just damaging the plastic housing.
    What is the best way to remove the speaker from the housing??
    Originally posted by 2010rz2 View Post
    What is the trick?
    Get ready to catch it with one hand and with the other after all screws are removed take the palm of your hand and hit the housing it will pop loose.
    FairTax.org
      There is a PDF tutorial that you get off the Wet Sounds web site.
      Lay a folded towel or something to cushion the driver. Tip it up on its edge, and pop it with your palm around the housing and the driver will walk its way out.
