We are replacing the PDX5 in our Tige with a Kicker 700.5 and when we pulled out the PDX5 we noticed that the power and ground for the 2 amps (Kicker 450.2 is the other amp) is 4ga from the battery but then splits down to 8ga going into the amps. The manual for the 700.5 says that power and ground need to be 4ga and I'm guessing the 450.2 has the same requirement.
My question is do we need to pull new power and ground wire so that we have 4ga going into each amp? I'm guessing the answer is yes but I thought I'd check (just in case) before we went ahead and did it.
Thanks in advance for your help!!
