BOAT TOWER STEREO WAKE BOARD RACK AND ASSORIES Infinity Kicker Sony
COMPLETE TOWER PACKAGE $995!
Antioch IL
Best to call my cell (area code THREE ZERO NINE) 27FIVE-909ZERO
If replying by email please include your email or phone number in subject line so I know your response is not SPAM
ALL IN VERY GOOD CONDITION WILL SEPARATE OR DISCOUNT FOR PURCHASE OF ALL.
TOWER PARTS
Polished Aluminum mirror clamp cost $195 new $90
Polished Aluminum rack cost $350 new $90
Despite being quite affordable! This system is VERY load and VERY clean very dependable! Sounds better than most “high end systems” I out blast that have a pair of tower speakers that cost more than this whole set up! 14 channels 2800 watts max 15 speakers runs all day on 2 batteries does not shut down.
STEREO SYSTEM
All prices each (one) item (NOT pair or all)
QTY 4 TOTAL MT8252BS - 8 Inch Black Double-Ended Marine Tubbies With MT-CL250-SS - Marine Tubbie Clamps with 1 clamp $99 each
QTY 4 TOTAL Infinity 6022i reference series speakers with grills and boxes $29 EACH
QTY 3TOTAL Kicker 12” sub woofers CVR12 07cvr122 $55 EACH
QTY 1 TOTAL 12” Ported sub cabinet $35 or $75 loaded with a Kicker
QTY 1 TOTAL Sony Xplod Xm-Zr1852 2-Channel 1000 Watt with box $75
QTY 2 TOTAL SONY XM-ZR604 Xplod 4 Channel 600 watt Amplifier with box $65 ea
QTY 1 TOTAL 5.1 channel EQ with blue lights with box $25
Buy the whole stereo set up for $895 or stereo, rack and mirror arm for $995
All prices plus just actual shipping
SPECIFICATIONS
Link to manufactures specifications:
http://www.bazooka.com/products/mari...e-Tubbies-P143
http://www.bazooka.com/products/mari...ie-Clamps-P216
3 Kicker 12” sub woofers CVR12 07cvr122
Model CVR12
Size (IN.,CM) 12, 30.0 Impedance (OHMS) 2 or 4 DVC Max Rec Amplifier Power (WATTS PEAK/RMS)* 800/400 Sensitivity (dB 1w/1m) 86.9 Frequency Response (Hz) 25-500 Mounting Depth (IN.,CM) 6 1/4, 15.9 Mounting Cutout (IN.,CM) 11, 27.8 Min Rec Sealed Box Volume (CU. FT., Liters) 1, 28.3 Max Rec Sealed Box Volume (CU. FT., Liters) 4.6, 130 Min Rec Vented Box Volume (CU. Ft., Liters)** 1.75, 49.6 Max Rec Vented Box Volume (CU. Ft., Liters)** 2.25, 63.7
o Enjoy your music even more with 2-way speakers
o Car audio system includes a pair of 6.5-inch speakers
o One woofer cone with edge-driven textile dome tweeters
o 60-watt power handling at 2 ohms (120 Watts peak)
o 53Hz - 21kHz frequency response
o Enjoy improved bass response, thanks to Plus One technology
Dimensions:
6.5 in. x 6.5 in. x 2.4 in.
Materials:
Electronic Components
Model No:
6022i
Sony's Xplod amps combine form and function in a mix that'll make your system look and sound great. On the outside, the sleek inverted heat sink keeps vital internal components running cooler and lasting longer. Removable terminal covers keep all the wire connections protected and out of sight for a clean-looking installation.
Description:
· 110W x 4 Max Power into 4 Ohms
· 150W x 2 (at 2 Ohms) + 300W x1 (at 4 Ohms) Max Power
· 60W x 2 RMS into 4 Ohms
· 65W x 4 RMS into 2 Ohms
· High Level Sensing Power On
· 80Hz High Pass filter with -12dB/Octave Slope
· 80Hz Low Pass Filter with -18dB/Octave Slope
· MOSFET Power Supply
· RCA & speaker level inputs
· Line level thru-put
· CEA-2006 Power Compliant
Output Power:
· CEA Rating: 60W x 4
· DIN 45500 Rating (@ 14 V, THD 0.5 %)
· 4 ohm: 4 x 60W
· 2 ohm: 4 x 65W
· Rated/THD (@ 14.4 V, 20 Hz - 20 kHz)
· 4 ohm: 4 x 60W / 1.0% (14.4V, 20 - 20kHz)
· 2 ohm: 4 x 65W / 0.1% (14.4V, 20 - 20kHz)
· Maximum (@ 14.4 V)
· 4 ohm: 4 x 110W
· 2 ohm: 4 x 150W
Input:
· Low Pass Filter: 80Hz
· LPF Roll Off Rate: -18dB/oct
· Subsonic High Pass Filter :: 80Hz
· Input sensitivity: 0.3 - 6Volts
Output:
· Frequency Response: 5Hz - 50kHz
· Tolerance: +0 / -3dB
· Total Harmonic Distortion (@1 kHz): 0.005%
· CEA SN Ratio: 97dB
· Min Load Impedance/Ch: 2 ohm
General:
· Current drain (@ Rated Power - 4?): 33 Amps (at 4 ohm)
· Weight (approx.)(kg): 3.1
· Dimensions (WxHxD in mm) approx: 396x55x256
Sony Xplod Xm-Zr1852 2-Channel 1000 Watt Car Amplifier – Xmzr1852 Some sum upon this object include: -Maximum energy outlay of 380 watts per channel during 4 ohms. -Maximum energy outlay of 1000 watts briged mono during 4 ohms. -Built in Low Pass filter 80 Hz 18db per octive. -Hi turn intuiting energy upon underline allows section to be activated but need for remote trigger. -Pulse energy supply It comes with all accessories
Antioch IL
TOWER PARTS
STEREO SYSTEM
SPECIFICATIONS
Model CVR12
Dimensions:
Materials:
Model No:
6022i
Description:
Output Power:
· 4 ohm: 4 x 60W
· 2 ohm: 4 x 65W
· 4 ohm: 4 x 110W
· 2 ohm: 4 x 150W
Input:
Output:
General:
