Ok, my new tower speakers will not play very loud at all. I checked the connections and fuses but all are ok. Spoke to the factory at Tige and the settings are set like they said. Any ideas why they will not play as loud as the others when the volume is being turned up? I have two amps that run the whole system which includes 6 floor speakers, subwoofer , and the tower speakers. All other speakers play great.
Wetsounds 80 tower speakers not loud
I found I had to turn the (high/mid/low) gain down on my interrior speakers and MAX the gain on the tower amp to get those puppies blastin. I even played with the freq to get more mid/top range without the nasty distortion for the towers.
I only have two pro 60s so you shouldn't have to take measures as drastic as I have to get good sound for boarding/surfin2010 Tige RZ2 "Fully Loaded" 650hrs
Surf Ballast & Enzo Bag - 1235 prop
Originally posted by Vicseek View PostI found I had to turn the (high/mid/low) gain down on my interrior speakers and MAX the gain on the tower amp to get those puppies blastin. I even played with the freq to get more mid/top range without the nasty distortion for the towers.
Seriously, gain setting knobs are NOT volume knobs and treating them as such will end up damaging your gear. Wet Sounds has those amps set correctly upon installation at the factory. Also changing the cross-over filters from High-pass to to Full-Pass or Low-pass will certainly blow a speaker to two.
Not trying to an asre, just bad advice to be passing alongMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Took the Z1 into Tige and special thanks to James and Harvey for getting my Wetsounds working great. Sounds like a totally different system when tuned right. Got the sound system fixed, graphics trimmed up, and 20 hr service done. Now ready for the lake and a 4 day vacation at Lake LBJ at the end of July.
