I put a couple of cheap MTX speakers on my tower and I don't know what to do with the wires. Right now I have them run through the tower to the port side. I could not run the wires through the base plate of the tower so I just drilled a hole next to it. I know it's not the best way to go but it's done... Do you guys have any suggestions to make it look better. I was trying to find something like a through hull fitting that was really small but have had no luck. Thanks for any advice you may have!!
Tower speaker wiring
Use wire loom and rubber grometsLast edited by whitlock87; 06-10-2011, 04:04 AM.Tige, it's a way of life!
i tried to redo the wiring for my tower speakers as the dealership had used cheap wiring and split the connection instead of running a line for each speaker. I have no clue how the dealership was able to run it through originally as i failed miserably at running new wire. i am pretty sure you need to remove the tower where it attaches to the boat. I will be dropping boat off at a stereo shop i have dealt with and they said it wouldnt be a problem.
After I drilled the holes in the tower, I used a piece of thread wrapped to a cotton ball.
I then used a vacuum to suck the cotton ball through the tower and out the other side. I used the thread to pull a stronger string through and then used the string to pull the wires.
In your case, I would have used the old wires to pull the new ones.Tige, it's a way of life!
