Clarion CMD4A code 5
    When I try to play a cd I'm getting a code 5 which according to the manual means cd is upside down but I have tried inserting the cd both ways and still get a code 5 anybody had this issue? And ideas on a fix?
    store bought or burned cd? try some electronics cleaner spray.
      Store bought cd and I tried several. I think ill take it apart and clean the inside
        Not to hi-jack a thread but where is the aux input on that deck?
        "I refuse to answer that question on the grounds that I don't know the answer."
          On the back. You should see a pair of RCA's with red leads.
            okay found them all taped up in the harness. works wierd when pluged in. volume control only works off the phone. is there a setting i can change?
