Wetsounds Pro 60s LED Speaker Rings
    Does anyone know where you can buy LED speaker rings for a set of Pro 60s? I’m looking for the ones that you don’t have to replace the front grill of the speaker.
    Thanks
    http://www.earmarkcaraudio.com/Xcart/home.php?cat=265
      Thanks man!
        Wow! Thats some EXPENSIVE stuff!!!!!!!!!!
          Materials are not cheap and there is some manual labor involved as they are hand assembled.
            Over on WW there is an article on how to make them yourself which you can do for cheaper but it's not really all that simple and you will definitely have a quite a bit of time into it. Time is $$$
              Time is money and lexan is NOT cheap. I'll assume someone is having their rings done with CNC as well. I would think Tim White could capitalize on this product / market with his mfg connections.
                Heck, i'll tell ya how to make them, still dont make it all that cheap.
                big sheet of .5" acrylic (try mail-ordering it )
                apx 18" p/ring of encapsulated waterproof LED strip @ $15.00 p/ft (still cheap, huh )
                2-part waterproof fast-setting adhesive that needs to cure clear
                CNC machine to cut the rings (a router leaves tool marks that are hard to polish out so they defuse the light) Im sure we all have one of these collecting dust in the garage
                Depending on what type of speaker pods you have, you may need to add a couple binding posts for the LED's + and -.
                  Chap...time is money. Neither you or I have that kind of time.
                  It would be nice to see Tim corner this market in mass. Seems like it would be a high margin item mass produced.
                  Agree?
