On board Charger
    On board Charger
    Which on board charger do you use? Any issues?
    Gandger mtn has the Pro Sport chargers on sale.
    ProMariner® ProMite Onboard Battery Charger
    ProMariner® ProSport Onboard Battery Charger
    Minnekota
    Guest
    I had minnkota in my fishing boat I just had replace after 6 years, and the pro sport in my last Tige which seemed to work well. Just wondering about alternatives ??
    Life is good...
    Happy Wife Happy Life
    I have had a Pro Sport for the last two seasons and had no problems.
    Formertigeowners.com
      Guest 12/24V 10A 2 Bank Charger #2611A
      I have had this one for 2yrs and it works great. I have interstate batteries one 24M-XHD cranking and one SRM-29 Deep cycle for the stereo.
        I had a 3 bank pro sport and it worked quit well. Not as many charging amps as a minnekota or a high end brand but it is better to charge at a lower amp rate.
        Life is good...
          I have a two bank in the Tige and a three in the bass boat. Had them close to five years with no issues. I use the Pro Charger I bought at Bass Pro.
            This winter I installed Xantrex Truecharge2 20 amp charger that will charge 3 batteries. And each battery can be programmed separately so different battery types can be mixed. It is a high quality charger that I picked up on sale for $210 which included a remote readout panel and temperature sensor- the sensor adjusts charging based on battery temperature.
              What store did that come from?
              Life is good...
                I bought it online from Hodges Marine Electronics, www.hodgesmarine.com.
