Tower/transom video and driver monitor?
    Ideas for a camera mounted on the tower or transom with a video feed to a driver monitor have been discussed in several threads. For newer Tige's, there is the factory tower camera. And Ragboy posted about feeding a Go Pro into the 2010 TigeTouch.
    I am interested in a video camera solution for pre-2010 Tige's. One idea is a Go Pro on Ragboy's transom suction mount with a video output feed to the driver. But I am at a loss for what to use to display the video signal and whether there is a means to remotely turn the camera on and off.
    Ideally, you could you an Ipad but I do not know if video goes in.
    Any ideas?
    You could always go with a mirror/monitor.
    http://wakevideo.com/accessories.php
      I'm keen on same setup or two cameras shooting at same time. one from tower, one from side mount - then editing two streams together. any comments?
