Im sure that your local dealer that helped you with your recent SW-808 and SD-6 purchase would be more then happy to extend that discount to a loyal customer such as your self. I must respectfully decline.
The long anticipated Wet Sounds Bluetooth receiver has finally arrived!
Wet Sounds is proud to announce our brand new WW-BT-VC. Bluetooth Volume Control. The BT-VC is a universal Bluetooth unit that allows you to add Bluetooth connectivity to any source unit. It is a perfect add on to a WS-420, head unit or a stand alone source unit. Now Shipping. MSRP $74.99
It has a 3.5 mm output. So all you need to do is jack a 3.5 mm cable from BT unit to aux input on WS-420 and your set. Bluetooth 420!
You can go 3.5 mm to RCA adapter and go right into an amp. or you can go into a head unit that has RCA aux input as well. Or 3.5 mm to a head unit with a 3.5 mm aux input
Thanks for the heads up, Mike. Looks like a great accessory. Right now, when I want to change the music quickly from the helm, I hook up the iPod directly into the AUX jack of the 420. Problem is, the iPod's always flopping around, wire gets in the way, etc.
With this, looks like I can just plug the BT-VC into the AUX jack on the 420, connect the iPod (or iPhone) via Bluetooth, and not have to worry about the wire or where I put the iPod. Sounds good. One question -- any idea what the range is (how far the Bluetooth device can be from the unit and still connect)?
Coop, Im gonna try and get an order on tomorrow for one to go on our stereo cooler we are building. As soon as I can, I will try it out and post up a review.
A usable cooler with a complete self contained stereo in it.
