Wiring on the Metcraft Towers
    I have a 2000 tige and it has a metcraft tower on it. I want to put a sound system on it. The tower is solid and isn't hollow which will make wiring a beast. Any suggestions of how to wire this tower? Has anyone wired their system on this type of tower before? Any ideas help!!!
    My speaker wire comes up through the front side of the tower base (drivers side) and into the side of the tower above the weld. It had holes, but I had to increase their size when running larger wire. You exit the upright just below the Y and re enter just above the Y on the front bar. I think you could do the same at the lap joints on the rear bar but the factory did it on the front so I followed their lead. Mine then exit the tower just in front of each speaker. Put loom over the wire and it doesn't look bad at all. Attention to detail makes it look professional. Just look at some of chpthril's install photos for ideas.
