I am putting 3-24 series in the port consol to power my stereo system. I was going to connect the batteries in parallel. Off the third battery I was going to run a 4 gauge '+" and 4 gauge "-" wire to 2 distribution blocks to the plywood which will be holding my amps, and from there run 8 gauge to each amp.
My question is to connect the batteries in parallel do I need to use a 4 gauge wire or will 8 gauge be ok?
Thanks
Thanks
