what would be the best sub to be run by the kicker 700.5 if it makes a big difference i will build a ported encloure.
what sub to be run by a kicker 700.5
I have a 10" Kicker Comp VR in a ported enclosure and it sounds good but I think a 12" would sound even better. Make sure you get the dual 4ohm voice coils so you can run a 2ohm load to the sub channel of that amp. I had the 10" running free air from the factory and just building a box made a HUGE difference in the sound.
Here's the thread on my enclosure:
http://www.tigeowners.com/forum/showthread.php?t=9765Last edited by Timmy!; 08-02-2010, 09:34 PM.
Here are my recommendations:
1 or 2 KM10's in a sealed enclosure. Have not heard these in a ported, so I cant comment on the sound, but a pair in a sealed hits pretty damn good.
Single Kicker CompVr10 4 Ohm DVC ( runs great in an infinite-baffle)
Single Kicker CompVr12 4 Ohm DVC. (runs great in sealed or ported)
The Wet Sounds XS-10FA is a great match for the power of the zx700.5, but I do not like how it sounds in a sealed box and have not even tried it in a ported. It's best suited for an infinite-baffle setup.
The XS-12 is not a bad choice either, even though it's ratings are 500 rms/1000 max.
*EDIT* One more worth looking at, but I havent had a chance to hear yet. The Exile Audio S12D.
Just something to chew on......where are you planing to install it? What size enclosure can you get there? This may play in to the decision.Last edited by chpthril; 08-02-2010, 11:02 PM.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
it will be mouted on the drivers wall on an 03 24v. i really dont use the storage under that side so i think i have plenty of space for an enclosure. just thought you guy would know what souds best coming from this amp. any info is helpfull and appretiatedLast edited by dhdremodel; 08-02-2010, 11:52 PM.
Originally posted by dhdremodel View PostOk so i got a 12 inch comp vr 4 ohm dvc and i am planning the box and want to know if it matters if my port is coming out the drivers wall at the face of the speaker or if i can just port it inside the storage compartment. and how much difference will it make.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
so was timmy wrong to port his in the storage compartment every one said what a nice box he made.Last edited by dhdremodel; 08-04-2010, 11:49 PM.
