I was diagnosing why my tower speakers sounded like there was static while music plays, I disconnect the RCA wires and plugged them back in and all of a sudden the tower speakers stopped working. This is a 2017 tige z1 with dual amps.
Tower speakers stopped working
Yeah, never a good idea to unplug/replug RCA with the system powered up.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
The first year DSP amps developed a static issue after a number of heat cycles. With no inputs connected and the noise is still there, points to the amp. One last step to be sure, is to a spare RCA and plug one chnl into the LEFT and the other end of that same chnl into the RIGHT. This grounds the inputs, preventing them from an antenna. If the noise is still there, its the amps. Given the year and the symptom, im 99% its the amps.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
chpthril I replaced the amp with a kicker and all the problems went away. Is it okay to split the 4 gauge wire small enough to fit into the new amp? I know there’s more professional ways to do this but is it safe? Here’s the final install.Attached Files
The reason the noise "went away" when you swapped out the wet sounds for the kicker is because the wet sounds compression driver is 10X more sensitive compared to the kicker traditional dome tweeter. The noise was still there, it was just harder to hear.
I would not whittle down the power cables to make them fit. Proper terminals, new cabling, amp that can accept the existing cable gauge or a distribution system that will allow for the cable to be stepped down.
I do not know if that boat has fuses or breakers for the amp B+. Would need to trace them to their source.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
