Hey Tige fam!
I’ve got a wet sounds HTX-6 set up to run my six in boat wet sounds speakers. 100 watts to each at 4 ohms.
The amp pushes these speakers perfectly and when it’s working the stereo jams. My problem is some of the time it goes into protect mode. I’ve looked up the code and it is indicating I have a short on all channels.
I’ve sent the amp to wet sounds for testing and they have assured me there is no issue with the amplifier. I’ve also been through all the wiring several times making sure connections were good and it was hooked up correctly. What I think I’ve narrowed it down to is possible engine starting current spike that sometimes causes it to go into protect.
I’m curious if anyone knows anything about this and has any suggestions on how I can go about fixing it.
Thanks in advance!
Thanks in advance!
