I have a 2016 R20 with a Wetsounds Syn6. While cleaning I bumped the wiring on the amp and pulled a wire off. Sound from the speakers immediately stopped. I found a smaller gauge wire that looked like it was piggybacked on the main ground feed from the battery pulled out. After re-terminating I have no power light on the amp. The head unit powers on. With a meter I verified power to the amp from the battery is 12v. Fuses verified good with an ohm meter. It’s a blue wire with a white tracer(although it seems like there isn’t a common color code to these boats!).
Could this be the wire that sends the signal from the head unit to the amp to initiate the amp to come on? I’m now wondering if it pulled out from the positive side and that’s why it’s not powering up. Any ideas would be appreciated. Thanks
