I've got the stereo wired for the most part... The last thing I have left to do is to put the connectors on the 1/0 gauge power and ground going to the battery as well as the power that passes therough the marine rated circuit breaker that is 18" from the battery. My question is how do I crimp the crimp-on rings that link the power cable to the connector? My Crimping tool doesn't look like it will be strong enough nor do I think I have the strength to do it. Here are some pictures of the intall that I have done so far... I was up until 6 this morning trying to get the thing patched up so I could use it this weekend. I hope that I can finish the job but I need some help fast...
I know my installation needs some work but this was my first attempt so be gentle please..
I'm still working on it too so if u see wires dangling that's because I had to call a quits once I saw the sun soming up.. And sorry for the fuzzy pictures.. after so many yuenglings that's what happens..
Also a quick question about the sub... Why does it have two positive and two negatives on it..? I thought maybe for convenience depending on how or where you installed it...?
