So I just purchased a 2013 z3 with the wet sound system and tower speakers. The speakers are not working and the amp is blinking red. Looks like 1 big then 5 faster. The second amp has no power light. Radio has power. Was wondering how to fix it. Any help would be great.
No sound out of speakers.
Are they both the shiny stainless amps? Is it the larger of the 2 thats flashing the 15? Thats pretty much a terminal failure. About the only thing you can do is confirm there is proper voltage across the 2 power cables.
Do the same on the amps that has no power light. Check voltage across the power cables, then across the main ground and the small turn-on terminal. Voltage = amp dead. No voltage, find the inline fuse holder by the batteries and check the fuse, make sure its connected to the battery or switch, make sure the ground cable(s) for the amp is connected.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Yes, good chance the Syn-6 has failed terminally. As to the smaller Syn-2 with no voltage to across the power cables. Could be blown fuse or cable left off battery or switch.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Small shiny amp powers the tower speakers.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
