Ok, so I have a very unique set-up and situation. I have toyed with several different ideas, but I thought I would get some opinions on which option seems the most feasable/reliable.
I have a 2003 Tige 24i riders edition (the one with the really small access port due to i drive). I have run this system several different ways before, but I continue to have overheating/space problems with each install.
My tower consists of 6 speaker cans. I am thinking about running wetsounds xs-650-b in the cans (I know pro 80 would be better, but they are not really an option here). I am also looking to run 4 wetsounds xs-650-b in boat. Finally, I have an audiobahn flame-q 12 inch woofer that is installed under the drivers side kick panel with a custom enclosure that I buld behind it.
I have 3 kicker 1000 watt 4 channel amps for the speakers and 1 1100 watt audiobahn amp for the woofer. I am trying to tone that down to 2 kicker amps and 1 audiobahn amp.
The wetsounds speakers are 4 ohms, so it makes it very difficult to figure out how to run the tower speakers without running such a low impedance that I overheat the amps. I have thought of running 2 in series and one in parallel with those 2 in series (2.66 ohms). I have also thought of three in seires and bridged down at the amp (2 ohms).
For the inboats, they would just run on thier own amp (4 ohms each). I have tried the 2.66 ohm setup in the past and dealt with overheating. I have built an amp rack for the 4 amp setup, but it just gets too tight and too hot in the hull. Any suggestions on how to handle this situation. I know I could take 2 speakers off the tower and make this so much easier, but who wants to do that
Sorry for the essay, I tried to include all of the information with as little rambling as possible. Thanks in advance for your help/ideas!
