I just replaced the wet sounds module that runs the rgb lights on the tower speakers. My questions is I want to change the current wet sounds 6.5” speakers in the boat to the speakers with the rgb. I noticed what might be pre wired for the lighting? Is my assumption correct?
Rgb on tower speakers
What year boat? To my knowledge, Tige has not pre-wired the cabin for RGB LEDs. Are your speaker Recon or Revo? If Revo series, you just need the 4-way flat connectors and wire the boat.
mine is a 2018. But after looking again I think that wire went to cockpit lighting. So I will have to wires those in. The other thing I am not sure yet is the sea blaze 3 under water light. It is a dual color but I am not sure how to switch it. White is fine in the waters here or the blue.
Originally posted by chpthril View PostWhat year boat? To my knowledge, Tige has not pre-wired the cabin for RGB LEDs. Are your speaker Recon or Revo? If Revo series, you just need the 4-way flat connectors and wire the boat.
Usually a quick OFF and ON cycles to the other color/mode.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I have a 2019 R23. It was an option for the factory to wire up the inboats. It was very high $$$ for some wire and connectors, so I assume most people did not add that option. My dealer wired the inboats for me as part of the sale. The underwater lights should be wired to the touch screen. As [mention]chpthril [/mention] said, power cycle will change the colors of the underwaters, mine will do blue, cool white and a warm white/greenish.
I am on a roll now. I have the underwater lights figured out. I also found a plug for a light on the starboard side as they only installed one light on the port side unless starboard was removed for a repair but I doubt because I have not found any signs of repair work. I did replace the control module for the rgb lights on the tower speakers because the old remote was damaged and not working. I may need to mess with the remote more or something because all the tower speakers lights do now is flash red with the beat of the music.
Ok. I had to relink the remote to the new controller and I have all the lights on the speakers working now. I removed one of the covers to inspect the lights and some of them on the strip do not work unless I push on them. So I have to order the kits to replace those. But at least I got it going.
You may need to sync the remote to the controller in order for it to respond. Very common to need to do this with new controllers.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Let me know when you are ready to do some upgrades, I dont just provide the best tech supportMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Hey Guys. Don’t want to hijack thread but maybe someone knows the answer to my question. I have a 2011 RZ2 with Rev 8 speakers. Was going to buy the west sounds led rgb speaker rings. I looked at you tube video for install and it looked pretty straight forward. Do I still need to buy a controller and wire that? Can I not do install and just have lights come on when speaker on? Sorry I am not tech savvy!
Originally posted by Tbird View PostHey Guys. Don’t want to hijack thread but maybe someone knows the answer to my question. I have a 2011 RZ2 with Rev 8 speakers. Was going to buy the west sounds led rgb speaker rings. I looked at you tube video for install and it looked pretty straight forward. Do I still need to buy a controller and wire that? Can I not do install and just have lights come on when speaker on? Sorry I am not tech savvy!Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
