Originally posted by Chill0987
View Post
Wet Sounds 3-Some on a 22i
Originally posted by Chill0987 View PostWhy not use epoxy? Would the chemical bond not be stronger with epoxy?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostAmps are on the outside wall of the port storage and distro-blocks are on the back side of the access door wall, just to the left of the door opening. The amps are mounted to pedestals that are epoxy-coated carpet covered and bonded to the the bare fiberglass.
Great looking install!!!
Originally posted by Lightning Rod View PostAm I assuming that you cut the carpet beneath the pedestals to apply the epoxy. Will that not allow moisture beneath the carpet?
J/K, not but a few inches above the amps is the top of the carpet anyway. If they is streaming water spraying/splashing on that area, the carpet will be the least of the worries. Even so, the carpet doesn't actually "seal" floor and walls from water.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
