From my tower speaker install this spring I have repeatedly noticed that after jamming some tunes for a while I will hear the highs/treble cut out from my tower speakers. It seems to be both speakers but haven't been able to fully confirm this 100%. It's an obvious change in the depth and quality of the sound when this happens. Something with my amp? (a new Kicker 4 channel amp that I've bridged). I do have a line signal driver in use to amp the signal to my dual zone fader control knob at the helm. I seem to notice this happening at higher volume levels.
Highs Cutting out on Tower Speakers - Help!
What speakers is the amp driving? Very well could be a tweeter self preservation function. Hows the amp setup.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostWhat speakers is the amp driving? Very well could be a tweeter self preservation function. Hows the amp setup.
They are Kicker KM8's. Gains on the AMP are roughly 50%. I have hi-pass enabled and the pass-freq set fairly high as I was having bass distortion issues at lower settings.Last edited by skiguy; 08-11-2020, 10:04 PM.
50%'ish could be a bit high depending on the line driver's output.
What about the RCAs into the amp, are they bridged properly?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View Post50%'ish could be a bit high depending on the line driver's output.
I’ll verify the gains but I followed standard tuning procedure when I did the install. Ie. Head unit at 80%, Tune gains up until distortion and then back them down.
I called Kicker and spoke with a tech. What is happening is there’s a protection circuit on the tweeter and it’s sensing distortion and shutting down the tweeter. My setup has an inline signal driver/amplifier with adjustable gains. I put this in place as it was a 40ft run to my helm zone controller and then back to the amps.
I had the line driver gains maxed and the gains on the amp adjusted about 30%. When I was originally tuning the sound I couldn’t hear the distortion (maybe because I’m old and my hearing ain’t what it used to be). To fix, I but simply reduced the gains on the line driver and the amp until the tweeter stopped cutting out.
I will say the overall volume is noticeably lessened. I anticipate hearing the music clearly over the engine noise (I do have fae) will be an issue. This might be the case for HLCD speakers vs the coaxial.
Originally posted by skiguy View PostI called Kicker and spoke with a tech. What is happening is there’s a protection circuit on the tweeter and it’s sensing distortion and shutting down the tweeter. My setup has an inline signal driver/amplifier with adjustable gains. I put this in place as it was a 40ft run to my helm zone controller and then back to the amps.
Battery voltage at the amp or one of the speaker's impedence is dropping very low. You can monitor the voltage with a meter. The disconnect one speaker at a time and see if the protect light comes on under the original conditions.
As to the tweeters still cutting out, whats the EQ settings in the source unit? Is the highs/treble jacked?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostBattery voltage at the amp or one of the speaker's impedence is dropping very low. You can monitor the voltage with a meter. The disconnect one speaker at a time and see if the protect light comes on under the original conditions.
I’ll be replacing the head unit with a WS 420 BT and retest per your comments above. Can I use my test tool to measure impedance for my speakers?
u can measure the static impedance but that may not point to a speaker thats dipping low during use. working impedance fluctuates with the music.so good start, but not an absolute.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
